Date/Time: Thu, 17 Sep 2026 05:41:58 +0000
Number Bars
View Count: 1110
[2020-12-09 04:21:17]
gmorgan111 - Posts: 121
I am having problems understanding how to set up order flow/number bars within sierra charts. The last time i used order flow was with ninja several years ago. I would like to set it up in sierra but am having difficulty understanding all the inputs. Is there a video on setting up the numbers bars i can watch? Or is there someone proficient in this that can help me.
[2020-12-09 14:45:08]
John - SC Support - Posts: 47917
There may be videos from other users on the Internet, but there is not anything official from us on this topic.
Apart from the documentation, which gives you a set of Step-by-Step instructions to create a Numbers Bars chart, there is also a preconfigured chart in the Additional Files area that you can use to help get started with the Numbers Bars. The direct link to the file is here:
https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht
Refer to the information here for how to use the Chartbook:
Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support
Here is the link to the Numbers Bars documentation:
Numbers Bars
[2020-12-09 19:35:03]
You will need to translate the symbols used in that Chartbook. Do that with this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
Date Time Of Last Edit: 2020-12-09 19:35:14
