Date/Time: Thu, 13 Feb 2025 13:25:07 +0000
Merging Profiles
View Count: 736
[2020-12-08 18:55:10] |
OrderFlow - Posts: 26 |
Hi, Is it possible to merge multiple profiles instead of merging them one by one ? Apologies if its been covered elsewhere... Thanks in advance for your help |
[2020-12-08 19:35:49] |
John - SC Support - Posts: 37916 |
Refer to the information for Merge Profile Begin and Merge Profile End in here: Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-08 19:50:21] |
Muy bueno...gracias!
