Date/Time: Thu, 13 Feb 2025 13:19:56 +0000
Spreadsheet Study
View Count: 521
[2020-12-08 17:42:12] |
Sargon Petros - Posts: 57 |
Hi there, I'd like to implement a simple spreadsheet study that shows the change of an instrument over the day, week, and month. Is it possible to consolidate multiple instruments into a spreadsheet? If so, what is the easiest way of doing this? I've had a look at the Spreadsheet documentation but the examples are achieving more than what I actually need. Thanks |
[2020-12-08 19:24:23] |
John - SC Support - Posts: 37916 |
You would just need to add the Spreadsheet Study to each of the charts with the different timeframes and be sure you specify the exact same name for the Spreadsheet Name on the Chart Studies Settings window. This will then give you multiple sheets with each one having the different timeframe data. You can then work the data as you want. Refer to the information here: Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
