Date/Time: Tue, 06 Oct 2026 04:43:45 +0000
[User Discussion] - Hiding Attached Orders Until Parent Order is Filled
View Count: 1351
[2020-12-08 17:06:15]
RolandC - Posts: 54
Does this mean that the hidden orders will not be filled until the parent order is filled?
[2020-12-10 13:41:54]
RolandC - Posts: 54
[2020-12-10 14:52:34]
ForgivingComputers.com - Posts: 1239
No: What this setting means is the attached orders (which are pending orders) will not appear on the chart until the parent order is filled. This is also when the pending attached orders become working (but not filled) orders.
Attached Orders: Hiding Attached Orders on Chart Until Parent Fill
[2020-12-10 15:33:25]
RolandC - Posts: 54
Will any of the attached orders fill before the parent order, under normal circumstances?
[2020-12-11 02:22:30]
No. If they are OCO, then the parent order gets you into the trade when filled, and one of the attached orders (stop or target) gets you out when it is filled. The other order that isn't filled (the "sibling") is canceled.
