Date/Time: Thu, 13 Feb 2025 13:31:41 +0000
[Programming Help] - Studies import in ACSIL
View Count: 630
[2020-12-08 15:16:08]
User190501 - Posts: 96
Hi all,
How to import SC studies to be used in an algo code ? Should I import the whole code of a study in the new trading system code to use it. I assume it is part of the SC library and we have the two lines at the front of the code to import it but it seems this is not the case...
Is there any sample code for importing studies ? The only examples in the ACS source is only for using sc.movingavg which is a function and not a study ..
I would like to import highlowoftimeperiodextended how to do this .. I would appreciate anyone refer to me to a code example for trading systems that import other SC studies... I was doing this so easily in the spreadsheets but not sure how to do it in ACSIL .. Thanks for the examples in advance...
