Date/Time: Thu, 13 Feb 2025 13:21:16 +0000
Karl Hazan - kvha56
View Count: 541
[2020-12-08 15:03:36]
karl - Posts: 8
Dear Sir,
For unknown reasons the image is flickering for CLF21, please see here enclosed for your easy reference
Can you help me with this ?
I do not know what happening
For your info, all the others that I have such 6EZ20, ESZ20 etc... are all OK.
Thanks in adavance for your
Karl
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=46091
[2020-12-08 16:14:24]
John - SC Support - Posts: 37916
The only thing to try is turning off the option for Global Settings >> Graphics Settings >> Other >> Use OpenGL for Chart Graphics then restart Sierra Chart for this to take effect. Refer to the documentation for this here:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
