Date/Time: Thu, 13 Feb 2025 13:55:41 +0000
Big Latency
View Count: 651
[2020-12-08 15:02:10]
Crystal77 - Posts: 28
Before i use SC in a normal computer with 2 monitor 17" and its ok
Now i have a 1 monitor 17" and 4 monitor 32" the latency its extremely bad when i move the mouse in the chart, its very disaggreable, how i can do for resolve this problem ?
i use windows 10 64bit
[2020-12-08 15:08:32]
[2020-12-08 18:28:12]
It is hard to say what the problem is. Refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
It would help us if you post an image of one of the charts that seems like it is the source of the performance issue and then we can get a better idea about it. Instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
Also try using OpenGL:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
