Date/Time: Sun, 14 Jun 2026 04:09:20 +0000
flux en temps réel
View Count: 1175
| [2020-12-08 15:01:40] |
| User909322 - Posts: 4 |
Bonjour J'essaye de surveiller 10 positions sur l'eurex et sur l'ice us. Or le compte est bloqué à 5 et du coup je n'ai plus du tout de flux en temps réel même après avoir supprimé toutes les fenêtres et procéder à une déconnexion et reconnexion. 1) comment puis je faire pour retrouver mon flux en temps réel 2) comment puis faire pour surveiller 10 positions et pas seulement 5. Merci |
| [2020-12-08 16:11:10] |
| John - SC Support - Posts: 46668 |
From Google Translate: Hello
I try to monitor 10 positions on the eurex and on the ice us. But the account is blocked at 5 and suddenly I no longer have any real-time flow at all even after removing all the windows and proceeding to a disconnection and reconnection. 1) how can I do to find my feed in real time 2) how then to monitor 10 positions and not just 5. Thank you What you are asking about is a Data Feed issue, and you are not using any Sierra Chart data feeds, therefore you would need to talk to your data provider about this issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-08 18:34:17] |
We recommend using the Sierra Chart Exchange Data Feed for market data to solve this problem: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
