Date/Time: Thu, 13 Feb 2025 13:31:21 +0000
Flex renko - very long wicks against the setting
View Count: 565
[2020-12-08 11:45:42] |
manfretto - Posts: 117 |
Hi, what is the reason that flex renko set at 8-4-4 draws such long wicks as at 9.00 today at Dax future (DYZ20)? Please see enclosed. |
[2020-12-08 18:22:25] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Let us know if that resolves the problem. Be sure to re-download the data as explained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-08 18:22:33
