Date/Time: Thu, 13 Feb 2025 13:55:47 +0000
REQ: Shortcut key to bring the Sierra Main Window to the foreground
View Count: 583
[2020-12-08 10:20:40]
ycomp - Posts: 321
This would be really useful when working on a laptop and the chart window is detached and maximized.
If there's some way to do that already, please let me know. thanks
[2020-12-08 12:46:13]
ForgivingComputers.com - Posts: 1001
I don't think there is a single shortcut that will always work, but Alt-Tab cycles through all open windows. Shift-Alt-Tab cycles in reverse.
[2020-12-08 15:51:57]
John - SC Support - Posts: 37916
Also, within the Keyboard Shortcuts there is an option for Goto Chart Number. It does bring up a window to select the particular chart number, but it could be faster for you, you would just have to try it and see.
[2020-12-08 16:10:08]
ycomp - Posts: 321
thanks, my goal here is to access the main window so I can select a chartbook from the tabs to switch to. Another option would be if there was a way to pop up a list of chartbooks via hotkey.. the chart windows are detached and maximized so they block the sierra chart main window. Also, I know about the keys for switching to the next and previous chartbooks and I do use those sometimes.
