Date/Time: Thu, 13 Feb 2025 13:19:40 +0000
Missing ES Futures Data
View Count: 509
[2020-12-08 06:04:51] |
Furinkazan - Posts: 19 |
Data Service: SC Data - All Services Created a chart on ES futures (ESZ20) with the following settings: Chart Data Type: Intraday Chart Bar Period Type SEtting: 0-390-0 (390 minutes bar) Session Start Time: 06:30:00 Session End Time: 12:59:59 Data between 2018-03-10 and 2018-09-13 are missing. Deleted and re-downloaded the data several times with the same results each time. |
[2020-12-08 06:09:57] |
Is this a continuous futures contract chart? Follow through the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
