Date/Time: Thu, 13 Feb 2025 13:53:24 +0000
Text Display for Study from Chart won't display subgraph name?
View Count: 576
[2020-12-08 01:30:24] |
j4ytr4der_ - Posts: 946 |
I hope I'm just missing something here. I want to display the name of a subgraph on a chart, from a spreadsheet system on another chart. It seems like I should be able to just go into the Text Display for Study from Chart study and choose "Display subgraph name" but it doesn't do anything. Searching the help on this page - Text Display For Study - is of no help either as that particular input, has no help information! How can I get the name of the selected study, to show up on my chart? And for that matter what name does it choose anyway? I assume it's the Short Name? |
[2020-12-08 18:15:38] |
Display Subgraph Name for that study was not implemented but it will be in the next release. It will be the Subgraph Name, or the Short Name if it is set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
