Date/Time: Thu, 13 Feb 2025 13:22:25 +0000
using scrollwheel with mouseover inactive windows
View Count: 585
[2020-12-08 01:09:31] |
WhiskyTango - Posts: 8 |
Hi just trying to make things more efficient I currently have my scrollwheel to adjust the chartspacing. however at the moment i need to click or activate the window i want to adjust. is it possible to adjust any chart window with the pointer hovering over the chart, regardless if its active or not? also can i adjust trend lines with the first left click[ and hold], drag and then release? as oppose to click , release, then drag, then click again. thanks! edit: also is there a subforum or site where users share (free) chartbook setups? |
[2020-12-08 15:09:08] |
John - SC Support - Posts: 37916 |
1. You need to activate the particular window for which you want the scroll wheel action to apply. This is how the system works. 2. Refer to this setting: Chart Drawing Tools: Support Drag For Chart Drawing Creation/Modification (Global Settings >> Tool Settings >> General >> Tool Options) 3. Sort of - there is a Subforum for "General User Discussion and Programming Help" that is not moderated by Sierra Chart. You can access this directly here: https://www.sierrachart.com/SupportBoard.php?ForumID=5 It is also available at the top of the Support Board along with the main support board. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-08 23:37:15] |
awesome thanks for that! also with the global settings, which file is it saved under? |
[2020-12-09 03:39:34] |
The file in newer versions of Sierra Chart is Sierra4.config
