Date/Time: Mon, 21 Sep 2026 18:46:51 +0000
Changing Study Inputs From Keyboard - Inputting Time
View Count: 804
[2020-12-08 01:06:32]
Acro - Posts: 459
If I wanted to set up a macro shortcut to change input 39 of the volume by profile study on a chart (start time for profile), can this be done because the input is a time - eg 18:00:00 ?
I haven't been successful with a macro for this and I'm guessing it is because of the format of the input.
I have tried 18, 18:00 and 18:00:00 without sucess so I am guessing this is not possible ?
[2020-12-08 15:03:18]
John - SC Support - Posts: 47955
You cannot change Date/Time inputs from the keyboard. Refer to the 3rd paragraph in this section:
Chart Studies: Changing Study Inputs Directly from Chart
[2020-12-08 16:03:42]
It is not currently supported to change Date and Time Input values using this method but it will be in the next release.
We will update the documentation with how to do this.
Date Time Of Last Edit: 2020-12-08 16:04:56
