Date/Time: Thu, 13 Feb 2025 13:40:34 +0000
is my /VX chart messed up?
View Count: 483
[2020-12-07 23:14:09]
User425645 - Posts: 113
Hello, ill post a screen shot below. it seems on my /vx chart , price can tick between ticks (?). the picture will help explain it better. How do I correct this?
imageCapture.PNG / V - Attached On 2020-12-07 23:13:58 UTC - Size: 77.79 KB - 191 views
[2020-12-08 14:52:19]
John - SC Support - Posts: 37916
The standard Tick Size for that instrument is 0.01. Therefore, unless you have changed the Tick Size, the price levels for the bars is correct. The implication is that you changed the Ticks per Volume Bar in the Volume by Price study that you have to 5. Or you could have changed the Volume by Price Multiplier to a value of 5. Either way would give you the same result in what you are seeing.
Refer to the information here for the Volume By Price Setting:
Volume By Price Study: Ticks Per Volume Bar
And here for the Volume by Price Multiplier:
Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
And here for Tick Size:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
