Date/Time: Thu, 13 Feb 2025 10:48:21 +0000
I can't connect to CQG via Sierra Chart
View Count: 611
[2020-12-07 17:11:39]
User652303 - Posts: 1
I can't connect to CQG via Sierra Chart. Look message log.
Reading Internal Order ID file. | 2020-12-07 17:39:28.975
Reading Trade Orders file. | 2020-12-07 17:39:29.062
Reading Trade Positions file. | 2020-12-07 17:39:29.062
Reading Account Balance file. | 2020-12-07 17:39:29.063
UDPListener (1476). Port 22904 | Listening on UDP port 22904. | 2020-12-07 17:39:29.082
Software version: 2207 64-bit | 2020-12-07 17:39:29.082
Primary Thread ID: 118744 | 2020-12-07 17:39:29.082
Usage end date: 2021-01-05 | 2020-12-07 17:39:29.082
Enabled for: Sierra Chart Historical Data Service. | 2020-12-07 17:39:29.082
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-12-07 17:39:29.082
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-12-07 17:39:29.082
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-07 17:39:29.082
Current selected Data/Trading service: CQG WebAPI | 2020-12-07 17:39:29.082
Custom symbol settings values: enabled | 2020-12-07 17:39:29.082
Chart Update Interval: 500 | 2020-12-07 17:39:29.082
Intraday Data Storage Time Unit: 1 | 2020-12-07 17:39:29.082
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-12-07 17:39:29.082
2020-12-07 16:39:29 Local computer time in UTC | 2020-12-07 17:39:29.082
2020-12-07 17:39:29 Local computer time in SC Time Zone | 2020-12-07 17:39:29.082
2020-12-07 16:39:29 Server time in UTC | 2020-12-07 17:39:29.082
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-12-07 17:39:29.082
Program path: C:\SierraChart\ | 2020-12-07 17:39:29.082
Data Files path: C:\SierraChart\Data\ | 2020-12-07 17:39:29.082
OS Version Number: 10.0 | 2020-12-07 17:39:29.082
Locale Setting: C | 2020-12-07 17:39:29.082
DLLs: UserContributedStudies_64.dll, wolumen_64.dll | 2020-12-07 17:39:29.082
Allowed protected custom studies: | 2020-12-07 17:39:29.082
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2020-12-07 17:39:29.083
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-07 17:39:29.115
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-07 17:39:29.141
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-07 17:39:29.141
Received 5 login tokens. | 2020-12-07 17:39:29.206
Symbol settings MD5 received. Request ID: 1. | 2020-12-07 17:39:29.356
Symbol settings are up-to-date for cqg. | 2020-12-07 17:39:29.356
Files to Open on Startup | Opening file: ExampleChartbook.cht | 2020-12-07 17:39:33.261
CQG WebAPI | Connecting to server api.cqg.com | 2020-12-07 17:39:35.270
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-12-07 17:39:35.270
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-12-07 17:39:35.585
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2020-12-07 17:39:35.585
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2020-12-07 17:39:35.585
CQG WebSocket | Opening WebSocket. | 2020-12-07 17:39:35.631
CQG WebSocket | Sending WebSocket handshake. | 2020-12-07 17:39:35.631
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2020-12-07 17:39:35.775
CQG WebSocket | Server header | Connection: upgrade | 2020-12-07 17:39:35.775
CQG WebSocket | Server header | Sec-WebSocket-Accept: JW8URYjxMxPEh6gAeVzYlzTKISs= | 2020-12-07 17:39:35.775
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2020-12-07 17:39:35.775
CQG WebSocket | Server header | Upgrade: websocket | 2020-12-07 17:39:35.775
CQG WebSocket | Server header | | 2020-12-07 17:39:35.775
CQG WebSocket | Web socket state is now open. | 2020-12-07 17:39:35.775
CQG WebAPI | WebSocket connected. | 2020-12-07 17:39:35.775
CQG WebAPI | Sending market data logon message. | 2020-12-07 17:39:35.775
CQG WebAPI | Logon unsuccessful. Server message: Trader is not enabled to use Live - SierraChart. Contact your FCM. | 2020-12-07 17:39:36.272
CQG WebSocket socket (1) | CloseSocket call. | 2020-12-07 17:39:36.291
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-12-07 17:39:36.291
CQG WebAPI | Disconnected. | 2020-12-07 17:39:36.291
CQG WebAPI | Not reconnecting due to connection error condition. | 2020-12-07 17:39:36.291
CQG WebSocket | WebSocket closed. | 2020-12-07 17:39:36.291
CQG WebAPI | WebSocket closed. | 2020-12-07 17:39:36.291
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-12-07 17:39:36.291
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2020-12-07 17:39:36.334
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-07 17:39:36.334
[2020-12-07 17:40:00]
John - SC Support - Posts: 37916
This is the relevant line:
Refer to item #2 in this section (although the message is not exact, it is the same issue):
CQG Trading Platform Service: Common Error Messages
