Date/Time: Thu, 13 Feb 2025 13:42:50 +0000
Change price scale to percentage?
View Count: 1076
[2020-12-07 15:18:39]
User676707 - Posts: 13
I know it is possible to add the study percent change since open, however this shows just a single line.
I need a way so my candlestick chart shows percentage since open, or percentage change since start of year for example.
Is there any way to do this?
[2020-12-07 17:05:45]
John - SC Support - Posts: 37916
If you are asking for a way to display the value of the Percent Change Since Open above/below the candlestick, then refer to the following:
Study Subgraph Above/Below Bar as Text
If it is something else, then please give us additional information as we are not understanding the question.
[2020-12-07 17:57:55]
I want a chart that shows the percentage of change in candlesticks instead of in just a single line.
Date Time Of Last Edit: 2020-12-07 17:58:41
[2020-12-07 18:55:50]
There really isn't a built-in study to do what you are asking for. This would be something you would have to program yourself (or have someone program for you) using the ACSIL interface to Sierra Chart. Refer to the information here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
[2020-12-07 21:35:27]
Also refer to:
The source code of that study is available and you can modify it as needed.
[2020-12-07 22:12:34]
Ackin - Posts: 1865
User676707)
Do you mean something like the image in the attachment?
EDIT:
if yes you can download it:
Free1 Library (2020)
study: Percent Change Since Open - Bars
study: Percent Change Since Previous Close - Bars
Date Time Of Last Edit: 2020-12-07 22:58:22
imagePercent Change Since Open - Bars.png / V - Attached On 2020-12-07 22:11:33 UTC - Size: 59.18 KB - 347 views
