Date/Time: Tue, 22 Apr 2025 10:20:23 +0000
Is there a way to export TPO chart data?
View Count: 1310
[2020-12-07 06:24:12]
SabikiSensei - Posts: 76
with the data only including value area high, low, range high, low, and POC?
[2020-12-07 15:09:57]
ForgivingComputers.com - Posts: 1042
I have a custom study for sale that will export to CSV the following at the end of Globex Trading, and RTH:
Total Volume,Date,Time,Open,Close,Session High,Session Low,Time POC,Time VAH,Time VAL,Halfback,Volume POC,Volume VAH,Volume VAL,Total Volume Above Volume POC,Total Volume Below Volume POC,Total Volume Above Time POC,Total Volume Below Time POC,Initial Balance Range High,Initial Balance Range Low
Attached is an example for MESZ20-CME.
Send me a direct message or email if interested.
brad@forgivingcomputers.com
attachmentMarketStats.csv - Attached On 2020-12-07 15:06:00 UTC - Size: 33.73 KB - 399 views
[2020-12-07 17:03:10]
John - SC Support - Posts: 39395
If you only want the "value area high, low, range high, low, and POC", then you can use the TPO Value Area Lines study to get the Value Area High, Value Area Low and POC. You can then use the High Low for Time Period to get the High and Low and also determine the range. Refer to the following:
and
High/Low for Time Period
You can then export the data using the Export Bar and Study Data to Text File. Refer to the following:
Edit Menu: Edit >> Export Bar and Study Data to Text File
But, the underlying TPO information is not available for export through the User Interface.
[2020-12-07 20:51:20]
Also refer to this ACSIL function:
ACSIL Interface Members - Functions: sc.GetStudyProfileInformation
[2023-03-08 15:40:20]
kremat0r - Posts: 47
Is there any easier way how to export TPO values, without going to ASCIL ?
[2023-03-08 16:57:32]
Just what Brad offers above. Or perhaps someone else has developed something.
[2023-03-09 13:17:18]
Ok, so I need to do it manually. I dont know how to code :)
[2023-03-09 16:40:51]
We have a list of programmers that work with Sierra Chart at the following link that you can contact:
List of Third Party Sierra Chart Study and System Programmers
