Date/Time: Thu, 13 Feb 2025 14:38:22 +0000
Reversing on Stop Attached Orders
View Count: 556
[2020-12-07 06:00:40] |
User606491 - Posts: 164 |
When using the Trade Window for Chart and creating a pre-configured attached order set: I would like to create a pre-configured attached order set that does not use a stop, but rather executes a reversal (i.e. if initially long 5 contracts and reversal point is hit, then sell 10 contracts). The guidance in the following link is helpful: Specifically, "Reversing on Stop Attached Order" (Attached Orders: Using a Preconfigured Attached Orders Set) However, point #5 suggests that I must wait until the parent order fills before adjusting the quantity on the Stop Attached Order. Is there a way to adjust the quantity on the stop attached order BEFORE the parent order is filled? Ideally, this would all be done at the time the trade is placed. |
[2020-12-07 21:13:38] |
No this is not supported. We will have to look into supporting this later.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-07 21:13:47
[2020-12-11 18:35:26] |
User90125 - Posts: 715 |
+1
