Date/Time: Thu, 13 Feb 2025 10:46:20 +0000
DATETIME_TO_YMDHMS
View Count: 495
[2020-12-07 01:59:15]
marcovth - Posts: 61
int iDate = sc.BaseDateTimeIn.DateAt(i);
int iTime = sc.BaseDateTimeIn.TimeAt(i);
int iYear,iMonth,iDay,iHour,iMinute,iSecond;
DATETIME_TO_YMDHMS(iDate,iYear,iMonth,iDay,iHour,iMinute,iSecond);
TIME_TO_HMS(iTime, iHour, iMinute, iSecond);
Hello ...
This used to compile perfectly fine for years.
Now suddenly it's giving ... error: call of overloaded 'DATETIME_TO_YMDHMS(int&, int&, int&, int&, int&, int&, int&)' is ambiguous
I had to find in the h files that DATETIME_TO_YMDHMS is replaced by GetDateTimeYMDHMS(iDate,iYear,iMonth,iDay,iHour,iMinute,iSecond)
When you search the website with "DATETIME_TO_YMDHMS", there is nothing to be found. You would expect some explanation in help files for how it has changed.
Anyway, whatever I try, I keep getting errors with GetDateTimeYMDHMS.
How do I solve this code?
Thanks in advance.
