Date/Time: Thu, 13 Feb 2025 14:21:30 +0000
Multiple Spreadsheet Trading Systems, Same Symbol, Separate Rules
View Count: 569
[2020-12-06 20:07:00] |
User355030 - Posts: 163 |
Is there a way to have multiple independent spreadsheet automated trading systems running with the same symbol and not having rules conflict?
[2020-12-10 08:25:22] |
Yes, if they are using different trade accounts. That is the best way. Refer to: Automated Trading Management: Using Multiple Automated Trading Systems at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-10 16:32:11] |
@SCE I mean that isn't a great option. Anything on the road map to keep chartbooks data on the same instance completely separate?
