Date/Time: Tue, 15 Sep 2026 07:23:39 +0000
Hiding the current candlestick
View Count: 1072
[2020-12-06 18:27:14]
User645832 - Posts: 99
Hey, is there a way to hide the current candle on the chart (the one that is forming)?
I read here that it was possible to set its color to the same color as the background, does this work?
[2020-12-06 19:49:11]
Ackin - Posts: 1865
tomgilb solved it:
Hide currently forming candle
[2020-12-07 01:03:46]
You could probably do this using the Color Bar Based on Alert Condition study:
[2020-12-07 09:25:44]
Thank you, I am trying it and I know I'm close, but I am not getting the result I want.
If I use the alert condition =C[1] then the study affects all the candles except the current one.
How can I reverse that?
What condition can I use to indicate the current candle?
