Date/Time: Thu, 13 Feb 2025 10:53:04 +0000
Update
View Count: 522
[2020-12-06 17:50:28] |
User161549 - Posts: 81 |
I received a notification when I opened sierra charts stating there was an update on the system, Can you confirm if there is an update and if so what it is I need to do to get the process started Thanks |
[2020-12-06 19:39:57] |
Yes in your case there is definitely a newer version available. Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
