Date/Time: Thu, 13 Feb 2025 11:12:59 +0000
[User Discussion] - attach order for trailing stop and be
View Count: 539
[2020-12-06 16:53:18] |
User847553 - Posts: 18 |
i set the attach order, 12 ticks trailing stop and move to breakeven for stop with offset in ticks trigger, be level 4, trigger offset 24. when complete, i want to automate adjust the trailing stop to 28, so how to set it, thx |
[2020-12-06 22:05:44] |
This is not very clear for us but have a look at a Trailing Triggered Stop to see if it does what you require: Order Types: Triggered Trailing Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-07 18:18:04] |
if i want to use trailing stop 12 ticks, when it move to breakeven then change to 6 ticks for trailing stop. Is it possible to set this? thx |
[2020-12-07 18:18:22] |
for 1 contract
