Date/Time: Thu, 13 Feb 2025 11:03:50 +0000
creating custom bar period for chart shortcutcut menu
View Count: 1974
[2020-12-06 00:29:53] |
MMX - Posts: 119 |
I would like to have a 2 min bar selection in my chart shortcut menu. From everything I've read it looks like I'm limited to the listed bar periods and that's it. With the control bar buttons, you can put any time period that you want, no limitations at all. Is there any way that I can create a custom 2 min bar period for the shortcut menu. Thanks.
[2020-12-06 11:09:08] |
Ackin - Posts: 1865 |
Try setting up a chart with a 1 minute period and then whenever you need to press "2" and "Enter" on the numeric keypad. Shortcut is also possible, but I think the above is faster. |
[2020-12-06 15:21:56] |
MMX - Posts: 119 |
When you say "shortcut is also possible", are you referring to the chart shortcut menu and if so, how in the world do I get the 2 min bar selection onto my chart shortcut menu? Thanks.
[2020-12-06 16:11:33] |
Not directly to this action You can: 1) Press "2"+"M"+"Enter" https://www.sierrachart.com/index.php?page=doc/ChangingPeriodOfBars.php&CAID=default#Period_Keyboard or 2) User custom study as a button and shortcut to this button Control Bar: Advanced Custom Study Control Bar Buttons |
[2020-12-07 01:03:26] |
No this is not supported, although refer to: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
