Date/Time: Thu, 13 Feb 2025 11:13:19 +0000
Make Alert Respect drawn line (horizontal as a S/R level)
View Count: 551
[2020-12-05 12:29:21]
Chadly - Posts: 65
Is there a way to make it so that your alert respects a drawn S/R level?
Lets say I mark up a chart with levels from 5 years to current. They're just drawn horizontal lines. Can I some how code in a simple alert that says if candle is above or below drawn line? Or if candle crosses above/below drawn line?
Chadly
[2020-12-05 12:40:20]
Ackin - Posts: 1865
One option (and probably the easiest) is to use the Chart Drawing Alerts. Refer to the information here:
Chart Drawing Tools: Chart Drawing Alerts
Another is to use the Simple Alerts and reference the drawing in the alert. Refer to the information here generally for Simple Alerts:
Study/Chart Alerts And Scanning
And here specifically for how to reference a drawing in a simple alert:
Study/Chart Alerts And Scanning: Referencing Chart Drawings
trend line sound alert
How to set Alert EMA Crossover Horizontal Line
I can't get the alert, what wrong ?
EMA : ID18.SG1
Horizontal Line : UDID[302]
Try:
=CROSSOVER(ID18.SG1, UDID[302][0])
Help ! How to set Alert for EMA Crossover Horizontal Line
[2020-12-07 00:45:14]
You can use Chart Drawing Alerts for this:
