Date/Time: Thu, 13 Feb 2025 11:02:57 +0000
Length of Status Bar (v2206)
View Count: 860
[2020-12-05 02:50:00] |
User13668 - Posts: 294 |
I have just downloaded the latest version (was previously on v2092). The Status Bar in the Control Bar is now extraordinarily long such that not all the items in the Control Bar will show without using arrows to scroll. Previous version all buttons were visible with room to spare. See attached image for v2206 display. How can I shorten the Status Bar? |
[2020-12-05 03:10:03] |
User542430 - Posts: 50 |
Global Settings>General Settings>General4
[2020-12-05 10:17:23] |
Here is the documentation for this: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
