Date/Time: Thu, 13 Feb 2025 11:18:47 +0000
[User Discussion] - Displayfusion settings with Sierra Charts
View Count: 480
[2020-12-04 18:03:26]
User727034 - Posts: 21
When the PC sleeps my SC reverts to the primary monitor on 'wake' so I have to manually move it back to its own monitors. I'm having the same problem using DIsplayFusion. In fact, SC is the only app I'm using that will not revert using the DisplayFusion HotKeys after setting up a windows profile. has anyone else had this problem and found a solution?
