Date/Time: Thu, 13 Feb 2025 13:47:04 +0000
Numbers bars on SP500 index {$SPX} shows volume - what is it?
View Count: 918
[2020-12-04 17:46:58] |
HeyUgly - Posts: 251 |
hello being that the $SPX doesnt really have volume , if i put the NumberBars charts on the index, its giving me a footprint of volume , i am curious what that volume actually is coming from / how its being charted?? |
[2020-12-04 17:47:27] |
for reference , pic attached
[2020-12-04 19:29:02] |
That would be the volume that is received from the source data feed for the symbol. So we think it is the underlying volume of the index. But we do not know for sure.
[2020-12-07 14:48:56] |
Can you tell me why i cant get it in real time? i can go back any day but current and see everything. is there anything i can do to get the live underlying volume? right now delayed about 30mins and static Date Time Of Last Edit: 2020-12-07 15:53:28
[2020-12-07 20:55:38] |
For real-time cash index data, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes (Cash Indexes) We recommend using the symbol $INX and activating S&P Cash Indices exchange with the Sierra Chart exchange data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-07 21:00:28
[2020-12-08 11:53:20] |
thank you ive done it and all is good, can you tell me the difference between $INX and $SPX, the underlying volume difference is huge is there anyway to have live $SPX, $INX isworking fine, but the $SPX is delayed Date Time Of Last Edit: 2020-12-08 15:22:39
