Date/Time: Tue, 06 Oct 2026 09:48:33 +0000
Blank charts when I load .cht file
View Count: 1947
| [2020-12-04 17:17:14] |
| JimmyMoops - Posts: 3 |
Hi everyone - have a sierra chart question- I have a .cht file from someone elsethat I was trying to open in Sierra charts. When I open it - all the charts are blank. Been messing with it for a while but can't seem to figure it out. I have the sierra service package 5 right now. but not set-up yet with my broker for live data - so thinking that might be it. - new to sierra and trying to avoid these questions to the group , but kinda stuck. Any help would be appreciated.
| [2020-12-04 17:20:44] |
| John - SC Support - Posts: 48114 |
Most likely the person you received the chartbook from is using different symbols. Open the Chartbook then select Edit >> Translate Symbols to Current Service. Refer to the information here: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-05 11:12:55
