Date/Time: Mon, 05 Oct 2026 03:11:58 +0000
Monitor Sim account results
View Count: 1497
| [2020-12-04 16:25:54] |
| ManuelGraf - Posts: 16 |
Hello, I was wondering if there is any function to see statistics from my sim account? I need to see max. DD, profits in % etc. thanks |
| [2020-12-04 20:16:53] |
| ondafringe - Posts: 337 |
Trade > Trade Activity Log Change: "All Symbols (Non-Sim)" to "[Sim] All Symbols" Set "Date Range" Click "Apply" At top: Click "Statistics" |
| [2020-12-04 21:22:02] |
It didnt work. When I click on Chart stats then it works, but there is no max DD. Its just the DD which I had today. When I go to Statistics like you told me then it shows me nothing. I can see that here should be the statistics, but its only showing 0000's I attached 2 pictures to clearify Date Time Of Last Edit: 2020-12-04 21:27:46
| Attachment Deleted. |
| [2020-12-04 21:58:06] |
I don't have any SIM data to work with, but only thing I see that *might* be the problem: Try changing "SimAcc2" to "All Accounts" and click "Apply" |
| [2020-12-04 22:07:48] |
Another possibility: Since you've created another SIM account (SimAcc2), check the pulldown menu for "[SIM] All Symbols" to see if your "SimAcc2" is listed. If so, you may have to select that specific SIM account, instead. I've always used the default SIM account, so I'm just guessing. |
| [2020-12-04 22:12:25] |
I tried both before and nothing changed. It seems like my stats are safed but the Statistics Windows somehow just doesnt work.
Date Time Of Last Edit: 2020-12-04 22:12:52
| [2020-12-04 22:20:03] |
I've never created and used a custom-named SIM account, so I'm not sure what's going on. Maybe someone else will jump in, but I'm out of ideas. :)
| [2020-12-04 22:29:07] |
I hope somebody else can help. Thank you for trying 🙂
| [2020-12-05 11:07:31] |
Follow the instructions here: Trade Activity Log: Trade Statistics Tab Make sure you choose the exact symbol from the list of symbols you want to see Trade Statistics for. It will be a non-simulated symbol in this case since you are not using the internal Trade Simulation Mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-05 11:07:54
