Date/Time: Thu, 13 Feb 2025 11:01:36 +0000
Chart saying I'm in a trade but I'm not
View Count: 594
[2020-12-04 16:07:02] |
User148596 - Posts: 217 |
he chart is showing that I'm in a trade but I'm not. Just wondering what it going on and how to fix it. http://www.sierrachart.com/image.php?Image=1607097834967.png I opened a trading DOM for ESZ20 and there were no open trades I opened a trading DOM for MESZ20 and there were no open trades Thanks |
[2020-12-04 19:10:51] |
You are referring to the Net Profit/Loss. In this case refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-04 20:44:15] |
I'm sorry but that does not address my issue. In the sceenshot I sent you there is an arrow pointing to an open position (Trade:4@36...) I do not have a trade on of that quantity or from that price. Where is it getting this false information from? |
[2020-12-04 22:31:49] |
John - SC Support - Posts: 37916 |
That particular line is not showing you the open trade. It is just showing you the current selected quantity and the price level that your pointer is located. Refer to the information in Step #3 of the documentation here (and also the image to the right of it): Chart Trading and the Chart DOM: Entering Orders From the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
