Date/Time: Thu, 13 Feb 2025 10:45:29 +0000
Tools list, message log, simulation window - all are black and nothing appear
View Count: 459
[2020-12-04 15:02:58] |
User296966 - Posts: 6 |
Good day! As from above, after installation of the current version 9, I have to point mouse on the text, and only then can the text be read. How to restore it to the previous set up with white background, please. |
[2020-12-04 16:34:05] |
John - SC Support - Posts: 37916 |
It sounds like the setting for General Text Window Background has been changed to black. Go to Global Settings >> Graphics Settings - Global and select that item from the list and change the setting to white (or other color that you want). Refer to the information here: Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
