Date/Time: Thu, 13 Feb 2025 11:21:27 +0000
[Programming Help] - automated scaling out in Sierra?
View Count: 470
[2020-12-04 13:57:00]
Bertram The - Posts: 3
I'm trying to build an order which allows automated scaling out of a trade. The issue is that it seems unreliable: at times it works perfectly well, but in other cases it seems to open the trade well before it's supposed to happen. I was wondering if you could advise me where the mistake arises?
The first attachment is a document describing step by step how I build the order.
The second attachment is an example of how it (sometimes) opens up a trade before it's supposed to do it. I'm using chart trading and selected 'stop sell' at the level of 30060 to open a short position at this level. However, it opened this trade, while still being at 30069.
Hopefully there's a solution to this problem! Or is there perhaps an entirely different preferred approach to automate scaling out?
Kind regards,
B. The
imageScreenshot 2020-12-04 at 14.49.04.png / V - Attached On 2020-12-04 13:49:38 UTC - Size: 208.87 KB - 179 views
attachmentMoney Management Sierra BThe.pdf - Attached On 2020-12-04 13:49:48 UTC - Size: 1.31 MB - 245 views
