Date/Time: Thu, 13 Feb 2025 10:53:57 +0000
scale issue after 2204 upgrade
View Count: 581
[2020-12-03 19:48:13] |
User657945 - Posts: 226 |
After the upgrade I got an issue wiht the time scale 00 00 come out in the scale no change in settings new bar at session on or off does not change the situation. Never had this isssue in 5 years.See attached photo of one chart
[2020-12-03 19:56:55] |
Refer to: *IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-04 20:43:29] |
Ackin - Posts: 1865 |
User657945) *IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart Please make sure you really have a library for version 2199 and higher The control is simple Menu / Analysis / Studies / Add custom studies / Library name (File name and version for which it was compiled) Date Time Of Last Edit: 2020-12-04 21:04:56
