Date/Time: Thu, 13 Feb 2025 10:38:51 +0000
Switching from live to sim mode issue
View Count: 669
[2020-12-03 19:10:48]
User143517 - Posts: 68
Hi there,
I am trading one market live and another one on Sim. They happen to be ZC(CBOT) and CL(NYMEX) respectively.
Today I had open orders on both, thus I had to switch between modes in order to check each mode open orders.
While trading the live one, I had a stop loss placed on the Sim account that I thought had gotten hit. When I switched back to Sim mode, the stop loss appeared and got hit where price was at that exact moment. With that, two questions:
1) Does Sim mode stops get "frozen" if you switch to live mode, and if they were to get triggered they only do so if you switch back to it?
2) I am assuming that in order to trade both Sim and Live and avoid having to switch between modes, I might have to run another instance of SC. Can I use Denali on one instance on Live and on the 2nd instance on Sim?
Best Regards,
[2020-12-03 20:07:22]
1. Yes.
2. Yes you do need to use two separate instances. A sub instance will work fine. The solution to the problem is documented here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Simulated Trading in a Sub Instance
Use the First Method.
