Date/Time: Tue, 04 Nov 2025 18:18:11 +0000
Point and Figure
View Count: 2258
| [2013-04-18 16:29:49] |
| marty_nv - Posts: 85 |
Is there a way to expand the point and figure capability to include "Box size" and "Reversal" based on inherited tick value? (see Attachment) This would enable templates using tick fixed value to be applied to any chart without modifying the template. An example of a fixed 1x3 on symbol 6e (Euro) requires adjustment to .0001x.0003. If the tick value were inherited, this adjustment would be automatic. "The graph is built from the underlying data in the chart. If the underlying data is 1 minute, then the Point and Figure columns will be based upon 1 minute bar data. If the underlying data is daily, then the columns will be based upon daily bar data. If the underlying data is less than a minute or based on ticks, then the columns will be based upon that data." |
