Date/Time: Tue, 29 Sep 2026 04:42:37 +0000
Volume profile lines until future intersection
View Count: 1833
| [2014-02-16 14:21:01] |
| User49270 - Posts: 89 |
I have a tpo chart with volume profiles next to each. I am able to extend all my value and poc lines until future intersection on the tpo's but not on the volume profiles. When I input end of window on the volume profile that's the only time the volume profile lines will extend but only on the last profile.
| [2014-02-17 03:21:27] |
This makes sense. You need to set Extend Value Area/Point of Control to Until Future Intersection.
| [2014-02-17 11:02:44] |
Yes I have already tried to set the extend lines until future intersection, it works for the tpo profile but does not work for the volume profile that is side by side with the tpo profile on the same chart. Thanks
| [2014-02-24 00:26:09] |
To give you an update on this, we did look into this but the problem is with how the Volume By Price study works with the TPO Profile Chart study. The volume area and point of control lines cannot extend until future intersection. We will have to consider this for a future release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
