Date/Time: Thu, 13 Feb 2025 10:53:21 +0000
Price bars won't populate the entire chart.
View Count: 512
[2020-12-03 09:49:53]
User690267 - Posts: 13
The bars on the chart stop half way as if there was an invisible margin. Please see attached pic for a clear example.
I would like to have the bars go across the chart and populate it normally till they reach the right hand side where the price levels are. It's the first time i have come across this issue, i have checked the scale settings against other charts i have, but to no resolve.
How can this be done?
Date Time Of Last Edit: 2020-12-03 10:14:03
imageCapture-3-DEC2020.jpg / V - Attached On 2020-12-03 09:58:33 UTC - Size: 110.25 KB - 223 views
[2020-12-03 15:56:11]
John - SC Support - Posts: 37916
If your data is up to date but just not filling in on that part of the chart, then you must have the Fill Lock Space enabled. Refer to the information here:
Chart Menu: Lock Fill Space (Chart menu)
If, on the other hand, you are trying to get more data into the chart, then follow these instructions:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
Date Time Of Last Edit: 2020-12-03 20:08:47
[2020-12-03 18:19:25]
Fixed !!! Fill Lock Space was enabled.
Thank you so much
