Date/Time: Thu, 13 Feb 2025 11:03:36 +0000
ES. S&P500 Futures to Cash Premium CME|S&P Indices
View Count: 620
[2020-12-03 07:12:15] |
User991052 - Posts: 33 |
Support, The Above " Ticker " is not updating on my Quote Board. Q. Is this available under my current subscription? Service Package: 5 Data: Denali Data Feed Regards, |
[2020-12-03 07:33:59] |
You will not have access to those symbols with the data feed you are using. We have developed a new method to be able to calculate these premiums. It is documented here: Custom Calculated Symbols: Stock Index Futures Premiums Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-03 07:34:41
