Date/Time: Sun, 08 Sep 2024 01:39:35 +0000
Alert on multiple studies
View Count: 1790
[2014-02-16 13:58:09] |
YSS - Posts: 107 |
Hello, Is it possible with sierrachart to combine alerts on multiple studies, meaning, they would only give an alert if the alert on studie1 AND alert on studie2 is true ? Would be great if that would be possible on the SCANNING but not needed, I can open a chart for every symbol. Thanks. |
[2014-02-17 03:23:08] |
Yes. You need to create one single study formula that goes on one of the studies and references multiple studies. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#ReferencingOtherStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
