Date/Time: Thu, 13 Feb 2025 11:07:17 +0000
time and sales
View Count: 484
[2020-12-03 01:02:29] |
timin - Posts: 36 |
hi, when I use my time and sales chart, it works fine, but when I'm trying to change the background and colour of the ask and the bid, I go to graphic settings and do it there, but when I press apply or load settings, it doesn't change it on my time and sales tape. so I was wondering what I was doing wrong. thanks |
[2020-12-03 11:18:15] |
There are two Graphics Settings Windows. You need to use the right one. This is explained here: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
