Date/Time: Thu, 13 Feb 2025 11:05:40 +0000
Trendline m5 dont show in M15 M30 or h1
View Count: 604
[2020-12-02 16:23:32] |
User562957 - Posts: 58 |
Hello, my problem is I want to do lines in m5 or m3 these are many when i trade intraday. When I click in m30 or m60 i see twenty of those and cant see the h1 supports because there are too many lines. So how i can hide m3 m5 lines when im in my m30 or m60 chart.
[2020-12-02 16:31:37] |
John - SC Support - Posts: 37916 |
It sounds like you are changing the period of a single chart which has multiple studies on it. Given this (if we have it correct) then without your programming it, there is no solution to automatically hiding studies based on the chart period. You would have to either use different Study Collections, or manually hide/show the studies that you want. Refer to the following: Study Collections Another option would be to use multiple charts with the different timeframes and change between them, this way they would only have the necessary studies on each one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-02 20:09:01] |
It is not possible to hide Chart Drawings based upon a particular timeframe of a chart.
[2020-12-02 20:13:23] |
Ackin - Posts: 1865 |
It sounds like you are changing the period of a single chart which has multiple studies on it. Given this (if we have it correct) then without your programming it, there is no solution to automatically hiding studies based on the chart period. You would have to either use different Study Collections, or manually hide/show the studies that you want. Refer to the following: Study Collections Another option would be to use multiple charts with the different timeframes and change between them, this way they would only have the necessary studies on each one. or use chart linking ... manually https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber |
