Date/Time: Mon, 25 Nov 2024 14:28:37 +0000
ACSIL: plotting graphs from the same study into two different regions ?
View Count: 1149
[2014-02-16 09:00:52] |
User40117 - Posts: 56 |
I have an average volume graph (bars) in bottom region and two band graphs for main chart region, can i put them into the same study function ? I need both of them to trigger orders. Or do i create 2 studies and import data from one into the other ? ty |
[2014-02-16 12:51:33] |
docs: "It is not possible for a single study to draw in a Chart Region outside of what is specified with sc.GraphRegion" ok, so a workaround would be to import data from another function, how can i achieve this ? ty |
[2014-02-17 05:57:32] |
Refer to this section: http://www.sierrachart.com/index.php?l=doc/doc_ACSILProgrammingConcepts.html#UsingStudyData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-18 14:18:21] |
ok ty, but does this work when both studies (functions) are exported ? |
[2014-02-18 17:55:15] |
We do not understand the question.
