Date/Time: Mon, 28 Sep 2026 06:57:44 +0000
Symbol Limits
View Count: 821
[2020-12-02 07:41:52]
User978290 - Posts: 25
I was just downloading some stock data. Maybe 20 symbols at a time.
Close the chartbook and start my next 20. However there was this orange notification that says over limit 150 symbols.
No clue why it reach 150 while I was just using 20 at a time.
Is the limit 150 or 250?
I see in the control panel under "Real-Time Data Connections" tab
"Set the Number of Real-Time Symbols Per Connection" 250 or 500, no clue what 150 is. Can you please clarify?
I do plan on using the whole 250 symbols.
Thanks a lot!!
[2020-12-02 08:39:07]
The limit should be 250. We want you to reconnect to the data feed:
The limit should be 250. If you still see 150 let us know.
