Date/Time: Mon, 25 Nov 2024 14:49:31 +0000
Total Volume for the distance of a line
View Count: 1194
[2014-02-15 22:18:38] |
lou_diamonds - Posts: 39 |
If I draw a line on a chart, is there anyway for me to get the total volume between the to end points of the line? Meaning, if I draw a line that goes under 5 daily bars, is there a way that I can get the total volume for all 5 bars (added up together), just by drawing the line? It would be preferable for the volume to display beneath/above/close to the line. Thanks! |
[2014-02-15 22:23:06] |
Yes. Use the Tools >> Chart Calculator tool. Refer to the documentation for this tool for more information.
[2014-02-16 00:08:10] |
This is great! Exactly what I'm looking for. 1) Is there anyway to change the number of digits that appear after the decimal point? For example, instead of 52.5700 make it 52.57. 2) Is there anyway to add a comma in the volume number? For example instead of 1258640568 it be 1,258,640,568. Thanks |
[2014-02-16 09:30:20] |
1. What is the value of 52.5700? Is this a price value and did you draw the line within Chart Region 1? 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
