Date/Time: Fri, 25 Sep 2026 19:25:25 +0000
[User Discussion] - Spreadsheet Signal from Linear Regression End Channel study
View Count: 1244
[2020-12-01 19:01:18]
User351605 - Posts: 82
I would like to generate a signal from the LREC study in the spreadsheet system for trading, but I don't know how to accomplish it.
I have found an old reply from tomgilb in that regard:
"The Linear Regression End Channel study constantly redraws the lines so there is no way to compare the previous slope to the current slope, using a Simple Alert.
It would be possible with the Spreadsheet System/Alert study, by locking the TRUE state of a cell with a formula. Post again if you want the details."
Let's say I have a moving average as ID2.SG1, and the LREC study has the subgraph ID7.SG2 (spreadsheet column R) for StdDev High, and ID7.SG3 (column S) for StdDev Low.
Now, for example, I would like to have a buy signal when the MA is < than StdDev Low.
How can I lock the TRUE state in this regard and how to proceed then?
Thank you!
Date Time Of Last Edit: 2020-12-01 19:08:11
[2020-12-02 00:11:36]
Sawtooth - Posts: 4354
That quote is from a user trying to capture when the LREC study's slope changes from upslope to downslope, and vice versa.
Locking a TRUE is easy enough, but using another event to automatically release it can be problematic.
If you want to use this method, here is an example:
https://www.sawtoothtrade.com/example-9.html
Here's an easier way to get a signal when the ID2.SG1 crosses ID7.SG3 from above:
=CROSSFROMABOVE(ID2.SG1@3:ID2.SG1@4,ID7.SG3@3:ID7.SG3@4)
You'll probably need to set Signal Only On Bar Close to No, since it might not remain TRUE at close of bar.
Locking a TRUE would always be intrabar anyway.
[2020-12-02 15:49:51]
Thank you!
