Date/Time: Thu, 13 Feb 2025 10:30:38 +0000
Zoom Out
View Count: 678
[2020-12-01 18:12:51]
User925260 - Posts: 30
I was able to open a 500tk chart for gold futures and in some cases it shows me multiple days, but then it reverts to only showing 2 days even though I am applying the 20 days to load in the chart setting. Is there any way to show all the data available?
[2020-12-01 21:12:51]
John - SC Support - Posts: 37916
There is going to be a limitation on the maximum amount of bars that can be displayed at any one time on the screen. In the end, it is about the pixel spacing of the monitor that really controls this.
Refer to the following information to make sure that you have the bar spacing as small as you can get it:
Working With Charts: Changing Bar Spacing
