Date/Time: Thu, 13 Feb 2025 09:57:17 +0000
Cargando data primera vez
View Count: 478
[2020-12-01 17:17:23] |
User543464 - Posts: 14 |
http://www.sierrachart.com/image.php?Image=1606842892552.png Buenos dias. Estoy cargando por primera vez mi data. Pero se ha quedado colgada desde hace mas de una hora. Agradecere su ayuda. Saludos, |
[2020-12-01 17:40:41] |
John - SC Support - Posts: 37916 |
From Google Translate I am uploading my data for the first time. But it has been hanging for over an hour. I will appreciate your help.
The initial process can take some time to complete depending on how many days are set to load for the chart and your Internet speed. In general refer to the information here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.1 - Too Much Data to Load or Loaded But the other thing to do is to see if you can load just the current contract and not use the Continuous Futures Contract and make sure you get that data. Again, make sure the number of days to load is reasonable (30 or so). Then change it to a Continuous Futures Contract and see how long it takes to download the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-01 22:50:35] |
We want you to reconnect to the data feed. Instructions: File Menu: Procedure to Reconnect to the Data and Trade Servers And then follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-01 22:50:43
