Date/Time: Fri, 18 Sep 2026 00:37:00 +0000
[Programming Help] - SECONDS constant no longer defined
View Count: 950
[2020-12-01 16:26:43]
WarriorTrader - Posts: 259
The SECONDS constant is no longer defined in SC v2204. Is there a quick way to add seconds to the time? I guess just adding (1) to TimeValue will have the same effect since time is stored in number of seconds after midnight?
  int TimeValue2 = sc.StartTime1;
  int TimeValue = TimeValue2 += 1 * SECONDS; // no longer working
Revised for current verison:
  int TimeValue = TimeValue2 += 1; //SECONDS removed
Thanks,
--WT
[2020-12-01 16:32:03]
User907968 - Posts: 883
You can read about it here - https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156
More information here - Required SCDateTime Changes for ACSIL
[2020-12-01 23:58:22]
There is a new member function for this:
Working with the SCDateTime Variables and Values: SECONDS()
